Please help me im sooo confused
Username: Nik9567
California United states
ok, i bought a pair of rockford 10' subs, they are the punch series. Im very new to this stuff, i need to know what kind of amp to get. Ive been looking around at stores talking to the salesmen, they all told me a bunch of bs just to get my money. I was wondering what kind of amp, how many watts, channels, whatever i need fo my speakers. I dont want to spend a lot of money, but i want a loud car. Thank you for your time!
Username: Thrushdtd
New York
Post Number: 253
HI, What we need to know is the make and model of your subs along with thier specs such as RMS wattage and voice coil configuration. If you dont know post a like to the subs information. Also specify your spending limit.
Username: Nik9567
there rockford fosgate 10' subs and are the punch series.....umm it says on the back of the speaker pch-104 4 ohms
Username: Nik9567
oh yeah the spending limit would be prob at most 300 if at all possible
Username: Infinity_addict
Santa Rosa, California USA
Post Number: 26
yah, those are 100W RMS each subs, so it'll be easy to find a cheap amp to power them from ebay or something... try jl audio, the e1800d, or the RF punch p4002, or infinity 311a.
any other amp suggestions for this guy?
Username: Supraspyder420
Sammamish, Wa U.S.
Post Number: 64
Soundstream VGA400.2
Username: Dominirica012
Charlotte, North Carolina US
Post Number: 559
100 rms...thats hella easy to power..if you want to go even cheaper than those above^ you can look at mtx,jbl,and kicker...just look on ebay for any of the mentioned brands with either 200rms at 2ohms or 100rms at 4ohms X 2
go to walmart and they should have some V-R3 200W amps for like $80
Username: Nik9567
that walmart amp, is it a good one or a rip off? I found it on the internet, on walmarts site for $57. Is it just as good as the rest?
Username: Kd7nfr
Montpelier, ID United States
Post Number: 502
No, it's not. :D But with those subs, you probably won't hear much of a difference anyways. Those are VERY small subs, and don't take very much power.
Username: Nik9567
Post Number: 7
do you think it would be worth my money to just buy new subs and an amp then? I got these ones for free from my neighbor because he didnt want them anymore.
the walmart amp is pretty cheap (i.e.WALMART amp) but if you have low power subs like me (you do) then its not much of a difference
$57 geez, i paid 78.95 for mine
Username: Nik9567
Post Number: 8
oh, ok. Thanks for all of the help. If it wernt for you guys i would probably be buying a $550 amp for no reason. Thanks again
Username: Nik9567
Post Number: 9
Do you have any idea if this amp comes with a wireing kit, if not do you know where i can get one for cheap?
Username: Redrazor
Fort Walton Beach, Fl USA
Post Number: 35
Well if you are going to buy that amp from walmart then get a wiring kit from there too.
Username: Xdrummer03
Tenessee
Post Number: 46
Best amp for those subs is a P3001 in my opinion. P4002 would not be a very good amp for this scenario.
