why does my amp have 6 wires leading into the high level input area? I can only hook up 4 (2 from left speaker, 2 from right speaker). what are the other 2 wires for?????
download it from the manufacturer's website if need be.
Buddshawn
sounds like somebody put sand in your motion lotion, tough guy. Im not f'ing stupid. I dont have a manual because its used. Now, if you wouldn't mind. A LITTLE HELP PLEASE!!!!!!!!!!
good luck getting help on that one, kiddo. next time steal the manual when you take the amp out of someone's car.
bozo
Buddshawn
Well, looks like glass boy has a little helper. As soon as one of you two lovers let the air out of your head, let me know if you find a manufacturer's website for a Kingwood amp. But if your too busy gazing into each others eyes, I'll understand.............
