I just got my amp, sub, and installation kit. I know where to run everything but I don't know what to do with the connections. I recieved a bag of assorted items I could use for connecting but I don't know how to hook wires to them. Any advice
most connections are crimp on...you need to cut the wire to the desired length. strip off a bit of the outside covering on the end of the wire. slide the connection on. and crimp it down...and then connect to where you need to.
