Outdoor Speakers or Wireless?
John McA
Does anyone have recommendations for reasonably priced outdoor speakers? Has anyone ever used any of the wireless speakers and do they work well?
Username: Edison
Glendale, CA US
Post Number: 794
Outdoor speakers will sound better - Niles audio sounds good - ebay sometimes carries them,
Username: Edison
Glendale, CA US
Post Number: 795
Check hear for Niles outdoor speaker - Os-6 is pretty good model for $200.
http://www.hifitrader.com/dbprogram6.php?searchquery=Niles
John McA
I figured wired speakers would perform better, but I am dreading the wiring. My stereo system is on the opposite side of the house from the deck.
Username: Touche6784
Post Number: 496
you could always get a new reciever, duh.
John McA
Out of the budget, Chris and I also have a 400 cd player attached -- can't duplicate that.
Username: Joe_c
Oakwood, Ga
Post Number: 687
mirage oasis II outdoors for 100-200 pr depending on where you get them.
Username: Edison
Glendale, CA US
Post Number: 812
How long is the wire going to be?
Make sure it's thick enough - the longer the thicker it has to be.
Yeah, no 24 gauge this time.
Anoni
Christopher is nothing but a little s h i t less kid whose face is probably still full of pimples .....Grow up!
John McA
James, I figure the wire will need to be about 100 feet so I will do minimum 16 gauge and probably 14 gauge. I can get at the wall behind the stereo fairly easily and it will run right through the crawlspace. I am just not real sure about getting through the wall on the other side by the deck. Wireless sure sounds easier!
