Bronze Member Username: Griffin_andrewsPost Number: 18 Registered: May-05 | All, What makes, models, features etc...should I be looking for for universal remote. I have a basic Sony 50" HDTV, Onkyo AV receiver, Onkyo DVD player, Directv HDTV sat. I doubt I need the be all end all of universal remotes...just curious what you guys use / recommend. |
Silver Member Username: Joe_cOakwood, Ga Post Number: 713 Registered: Mar-05 | Phillips Pronto ng tsu3000 , great little thing. Expensive but so simple once you set it up. |
JBails Unregistered guest | I currently use a Harmony 676 and am very happy with its capabilities. I previously had a Pronto Pro, which cost about 3x the price, but I quite frankly found it too difficult to program and use. You can't go wrong with the Harmony range (www.logitech.com/harmony). |
Silver Member Username: Joe_cOakwood, Ga Post Number: 719 Registered: Mar-05 | Yes they are great remotes too. |
