Ohm question, is this true?
WC
Someone said that 2 4 ohm DVC can be wired down to 2 ohms? Is that true?
Username: Jaackdeth
United States
Post Number: 210
No, go here http://www.jlaudio.com/tutorials/wiring/index.html
Username: Shadow1290
Post Number: 21
yes, wire them in parallel and it wil creat a 2 ohm load
Speaker
\__ __/
+terminal
Wire the Posotive speaker terminal individally to both posotive terminals on both speaker coils (do same for Negative)
Wil Post link Later
Post Number: 22
http://www.installdr.com/TechDocs/999016.pdf
remember you want parallel
he obiousley has no concept of ohms law
-amatures-
dont post unless you know what your talking about
Post Number: 23
its sad when his own websight that he posted says that yes you can
**SIGH**
Do you understand what i told you + the links
Username: Glasswolf
Wisteria, Lane USA
Post Number: 8222
if you have a two channel amplifier, yes you can get a stereo 2 ohm load with a pair of dual 4 ohm coil subs
If you have a mono amp and two 4 ohm DVC subs, you'll need a 1 ohm stable amp, or an amp that puts out desired power at 4 ohms.
you won't get a 2 ohm mono load with that sub configuration.
Post Number: 25
thanks glasswolf for the reideration!
and make sure your amp is 1 ohm stable
Username: Jaackdeth
United States
Post Number: 212
Josh, look again, it says that 2 Dual voice coils that are 4ohms can be wired to 2 DVC drivers with Voice Coils in Parallel / Parallel
Connecting the voice coils of each driver in parallel (+ to +, - to -) and the drivers themselves in parallel (+ to +, etc.) will result in the following impedances:
Dual-6 Ohm Subwoofers: 1.5 Ohms
Dual-4 Ohm Subwoofers: 1 Ohm
Dual-2 Ohm Subwoofers: 0.5 Ohm
WC
Yea ok, all those look like SVC, not DVC.
Username: Jaackdeth
United States
Post Number: 213
N/M I though he said 2 subs! My mistake!!!
Post Number: 27
your going to argure with me and especially Glasswolf(<-- he is probably the most audio effeicent person on this forum)
WC
YES thanx wolf, I have a post on here called Sub box with subs question, some fool said I can wire doen to 2 ohms, hey can you read that post and help me out?
Post Number: 28
it's ok we all make mistakes
Username: Jaackdeth
United States
Post Number: 214
Josh, check out the post above you, I agree, I thought he said 2 subs, my mistake
Post Number: 29
dvc=dual voice coil
2@4 ohms each would have been clearer
Username: Glasswolf
Wisteria, Lane USA
Post Number: 8224
no harm no foul. sometimes it's hard to be clear when talking about DVC subs, too..
that's why I always say "dual 2 ohm coils" instead of 2 ohm DVC. I try to be clear about the load per coil so as not to get mixed up.
clintolner
I bought 2 6 ohm dual coil 800 watt subs, how should i power and wire them?
Username: Glasswolf
Wisteria, Lane USA
Post Number: 8326
should have thought about that before buying those subs :-)
dual 6 ohm coil subs are designed for a mono amp with 3 subwoofers.
