IMPORTANT Q!! PLZ HELP
Username: Legendx
i just installed 2 subs and 1 amp to my car. the amp is 800 watts. i drive an oldsmobile eighty-eight 1997. the amp wont stay on, it only blinks on for a second and turns off everytime i start the car or turn the key to acc. my battery is runnin 12 volts. is my battery not srong enough? would a capasitor help?
Username: Dominirica012
Charlotte, North Carolina US
Post Number: 493
check all your wiring..especially your ground(black) wire..make sure that its only in contact with metal and not any plastic or any other non-metallic items
Username: Legendx
i did but still no change...fustrating but this is the only way to learn. is there anything else they might cause it to do this?
Username: Fishy
Tamarac Ft.Laud, FL USA
Post Number: 1436
Try disconnecting the subs at the amp. If the amp works ok then you may have a short in your speaker wiring or a voice coil or your subs are wired in a way that presents too low of an impedance to the amp.
Which amp and which subs are you using and how do you have them wired? Most 2 channel amps are NOT stable below 4 0hm bridged and if have low impedance protection may very well shut off in that case.
-Fishy
Username: Glasswolf
Wisteria, Lane USA
Post Number: 8359
your question wasn't that important.
stop posting topics in all caps.
Username: Kd7nfr
Montpelier, ID United States
Post Number: 412
Yes... I thought something important was happening... And thanks for helping him Fishy :D.
Username: Legendx
was important to me man...my stuff wasnt working so i asked a question, i thought thats what the forum was for....help. thanks for the help tho quick shot and fishy, i got it to work.
Username: Fishy
Post Number: 1444
What was the problem? bad ground?
-Fishy
Username: Glasswolf
Wisteria, Lane USA
Post Number: 8378
the problem is your inability to read.. along with that of a lot of people around here lately.
next time you post a new topic, look just to the right of the topic field box, and read the part that says "Do not post topics in all caps."
one other small favor I'll suggest to help you get more help.
use a spell checker. words like "capacitor" aren't really that difficult to spell, and the little bit of added time in looking up a word you can't spell will help you in the long run.
glad you got it fixed.
Username: Kd7nfr
Post Number: 417
Lol. We need stickies for all the newbies. Answer 90% of the questions in the stickies, that way we don't have to do this every day... Just my .02.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 8392
I'm just old and grouchy.. like Oscar on Seasame Street
Username: Pjcom
Brentwood, TN USA
Post Number: 23
lol
Username: Kd7nfr
Post Number: 429
Yes.
Username: Fishy
Post Number: 1449
LMAO
I just imagined a Krell amp powering a pair of Martin Logans in a garbage can.
-Fishy
Username: Glasswolf
Wisteria, Lane USA
Post Number: 8400
good acoustics. no flat surfaces. :P
