Sorry if you guys have answered this before but I have a question about power spec.If an amp is rated at 2x150 @ 4ohms,2x300 @ 2ohms.and 1x600 @ 4ohms brideged.How much power would it produce to EACH sub if I have 2 4ohm svc subs wired at 2ohms.Basically what I'm asking how much power would it put out at 1x? @ 2ohms?
You can't bridge that amp at 2-ohms unless it says somewhere that your amp is 1-ohm stable, but it doesn't sound like it. Don't try it, it will make your amp go into protection mode, or worse yet, ruin your amp.
