Crossfire vr1000d
Username: Djeasy
the recommended wire awg and fuse size are 4 awg , 120 fuse, and 20 ft power wire, do i have to get a amp kit that has the following ,because they are hard to find,they are usualy 80 or 60 amp fuse with 17" or 18" power wire
Username: Carguy
Post Number: 3614
Just get a normal amp kit and buy the fuse separately. It shouldn't cost no more than $13 for 5.
Username: Suleman36
Maryland U.S.A.
Post Number: 1615
www.knukonceptz.com is where i got my wiring. And i own the same amp J-Dubb. Its gonna be pushing 2 12w6v2's ported to jl specs. What are you pushing with yours ?
Username: Djeasy
im thinking about pushing a 15" Kicker L7 ported,or maybe two 12" kicker l7's ported what do you think?
Username: Suleman36
Maryland U.S.A.
Post Number: 1625
I think it will get very loud and hit hard / BIG SPL ! Not sure about the SQ with those subs.
Username: Djeasy
i just want high spl,would you consider one 15 or 2 12's? also do anyone know if it is possible to wire two dual 4 ohm speakers at 1 ohm? or a single dual 4 ohm speaker to 1,or does the single sub has to be a dual 2 ohm to get lowered to 1,im new to the indepence of ohms, just trying to get the right subs setup for my crossfire vr1000d 1000 rms @ 1 ohms,thanks
Username: Suleman36
Maryland U.S.A.
Post Number: 1629
For 2 subs that are dual 4 ohm then yes you can wire it down to 1 ohm to match the impedence of the CrossFire at 1 ohm.
For 1 sub that is dual 4 ohm you can wire it to 4 ohm or 2 ohm only.
If you want more spl and listen to mostly rap then get the one 15" Kicker L7
Username: Djeasy
So get a dual 2 ohm 15" Kicker l7 with a big ported box, or small?
Username: Suleman36
Maryland U.S.A.
Post Number: 1633
Find out by emailing KICKER about what is the recommended size or calling them. Just get a Dual 2 ohm 15" L7 and go ported and you will get plenty of bass.
