Bronze Member Username: Zhep03Post Number: 16 Registered: Jul-05 | would 2 audioband 600 rms subs run off a 4x70 pioneer amp (300 watt)? would this work or would I have to get a bigger amp? |
Bronze Member Username: Infinity_addictSanta Rosa, California USA Post Number: 25 Registered: Jul-05 | get a bigger ampto specifically power the subs. you want to either match the RMS rating of the subs or overpower them a little. |
Bronze Member Username: Zhep03Post Number: 17 Registered: Jul-05 | What do u think i should get, what wattage of sub? |
Silver Member Username: Dominirica012Charlotte, North Carolina US Post Number: 498 Registered: May-05 | depends if its 600rms combined then buy a JBL 600.1 of ebay..if its 1200rms get you a JBL 1200.1 both are fairly cheap off ebay |
Bronze Member Username: Zhep03Post Number: 18 Registered: Jul-05 | well i cant from ebay, cause i got my regular from store, so i get store credit, but ill see if the got jbl amp, if not what else u think i should get? heres my subs i got http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem%26item%3D5790436084%26&sspagename=S TRK%3AMEWA%3AIT%26, ur help is greatly sensier |
