NTSC to PAL dv transfer
Username: Videodork
Hi, I'm a new user looking to convert a NTSC dv file to PAL. I've tried streaming the file but the sound is out of sync. Is there another method or possibly some free software out there that allows you to do it quickly and easily?
Any help will be much appreciated.
Username: Gromit
Post Number: 458
Andrew,
Upload the file to your PC in NTSC format and then use a video editing software such as Ulead VideoStudio to output into DV-PAL mode.
Ulead VideoStudio can sometimes be found free of charge on the cover of PC magazines.
Cheers
