New member Username: Egr70Post Number: 5 Registered: May-05 | In flash situations, I get an r07 error message and the flash does not fire. Have tried other settings, but no luck. Any ideas? Thanks. Brian |
Unregistered guest | You may want to check this site: http://www.nikonians.org/cgi-bin/dcforum/dcboard.cgi?az=read_count&om=4620&forum =DCForumID86 They say it's not an error and to check page 63 in the manual. |
Gold Member Username: Project6Post Number: 3241 Registered: Dec-03 | What size is your memory card? What setting are you using? |
