Silver Member Username: Sploosh56
Ohio
Post Number: 737 Registered: May-04
Posted on I know this has nothing to do with subs but what are some headphones that have amazing sound quality. Something that would just blow me away. |
Silver Member Username: Tbolt
Collipark,
GA
Post Number: 283 Registered: Dec-04
Posted on shure e5c if you can afford them. They are real bass heavy though. |
Silver Member Username: Illuminator
Post Number: 999 Registered: Apr-05
Posted on If you want good headphones rather than earphones, the Sennheiser HD280pro's are nice. Also check out the Ultrasone HFI-650 if you have more money. |
Silver Member Username: Ffxdevilarms
Dubuque,
Iowa
United States
Post Number: 577 Registered: Jul-04
Posted on 425 bucks for the sure e5c's. HOLY KRAP THAT IS EXPENSIVE AND NOT WORTH IT!!! |
Silver Member Username: Mikechec9
Chicago/atlanta
Post Number: 428 Registered: May-05
Posted on the oval shaped sony 7 series. forgot the actual number, but these are my absolute favorites. 75-100.00, depending on the store. |
Gold Member Username: Illuminator
Post Number: 1004 Registered: Apr-05
Posted on The MDV700s? They aren't bad...but for that price you could get the Sennheisers which spank the Sonys. |
Chicago/atlanta
Post Number: 433 Registered: May-05
Posted on really? that's incredibly hard to imagine, although i have heard only good things about sennheisers. will def give them a listen. my sonys broke |
Silver Member Username: Touche6784
Post Number: 498 Registered: Nov-04
Posted on wouldn't that be an indication that the sonys suck? |
Silver Member Username: Hellbender
Los Angeles,
California
Post Number: 128 Registered: Apr-05
Posted on lol |
Chicago/atlanta
Post Number: 436 Registered: May-05
Posted on 2shay. but they sure sounded great b4 they did. sony seems to have poor build quality across the board. looking forward to these others though. |
Collipark,
GA
Post Number: 287 Registered: Dec-04
Posted on I'll just stick with my shure e2c's. |
