New member Username: KentonioNassau, New providence Bahamas Post Number: 2 Registered: Jul-05 | How to wire down Audiobahn A1251 SE 4 ohm subs to 1 ohm? Include diagram if possible. I need it for an Audiobahn A1300HCT Amplifier. I need the subs to wire down to 1 ohm in order to get the full power of the amp. |
Silver Member Username: JaackdethUnited States Post Number: 215 Registered: Sep-04 | http://www.jlaudio.com/tutorials/wiring/index.html |
Bronze Member Username: Shadow1290Post Number: 33 Registered: Jul-05 | you cant wire them down to 1 ohm but you could get them to 2 ohms what you would do is bridge the amp then wire the speaker in PARALLEL which would present the amp with a 2 ohm load its very impontant that you wire them in parallel b/c if you wire it in series while te amp is birged it will present the amp with an 8 ohm load http://www.installdr.com/TechDocs/999016.pdf This link also has the basics of ohms law which will explain why this is (if you care) HAHA *GriN* |
New member Username: Xdrummer03Tenessee Post Number: 9 Registered: Jul-05 | Are those subs dvc's,antonio? |
