Sub box with subs question
WC
I was looking at the Kicker DCVR12, comes with 2 12' ComVR subs. I have 2 questions, the first one is does this come in the 2 ohm CRVS because I have searched and I think this combe only comes in the 4 ohm DVC's. My second question is this combo costs $400, if I buy just buy 2 of the subs it would cost alittle over $300, and then I would have to buy a box, which is better?
Username: Kd7nfr
Montpelier, ID United States
Post Number: 376
Custom box is best. And the 4 ohm DVC's can be wired into 4, 2, or 1 ohm loads if they're two of them.
WC
No you cant wire 2 4 ohm DVC down to 2 ohms, not to a mono amp.
