New member Username: JrxPost Number: 9 Registered: Jul-05 | is the orion 2500D overkill for 2 12 W7s. Is it too much power for them. i know the 1000.1 gives more than that at 3 ohms more like 1200 and if the 2500D is hooked up parallel to 2 W7s the load is 1.5 and it should be around 1050 wrms each? Can somebody verify this info and tell me if that amp will make them hit good? |
Silver Member Username: JaackdethUnited States Post Number: 192 Registered: Sep-04 | https://www.ecoustics.com/electronics/forum/car-audio/148904.html |
Silver Member Username: Dominirica012Charlotte, North Carolina US Post Number: 389 Registered: May-05 | no offense but why did you ask the same question again when the 1st time a highly experienced person told you that you'll be ok? |
New member Username: KentonioNassau, New providence Bahamas Post Number: 1 Registered: Jul-05 | Hey guys I have 2 12" Audiobahns pushing 800 watts peak and 400 watts rms per sub. I have a power acoustik amp that pushes 1920 watts peak and 880 watts rms. The Amp pushes 880W rms on 1 channel bridged @ 4 ohms and 1920 X 1 channel bridged @ 4 ohms. How can i wire my subs so that i can get the full 1920W instead of jus the 880W? If possible include diagram |
