stapler Unregistered guest | i was wondering if this package was a good deal, and if the subs would have good spl. i've heard good things about JL, but wasnt sure if the 12W3V2's were any good. http://www.acaraudio.com/product_info.php?cPath=24_47&products_id=1207 also, would it be better to buy the subs and the amp seperately? thanks |
Silver Member Username: Dominirica012Charlotte, North Carolina US Post Number: 387 Registered: May-05 | yea those susb have pretty good spl...you could probably find better deals on ebay by buying the amp/subs seperately but that setup is ight |
Silver Member Username: Mikechec9Chicago/atlanta Post Number: 403 Registered: May-05 | it's cool. but you can still do better for the price. i would buy 2 rlp-12's for 430.00 and one nine.1 for 300.00 and come out WAAAY on top before i went w/that purchase. and that is direct from the factory w/complete warranty. if those were w6v2's w/one 1000/1, then that would be a different story. |
Anonymous | Mikechec9....how good are those 12" w6v2's. I was about to buy 2 in a ported box to compete with my buddy's 2 12" L7's. I already know that the w6's would sound better but i still want to hit harder that him. both are in a ported boxes and in suv's |
Silver Member Username: Dominirica012Charlotte, North Carolina US Post Number: 393 Registered: May-05 | no the w6s will not hit harder but they wont sound liek @$$ |
Anonymous | d@mn....I want JL brand for my suv put i cant be second best. What JL setup would you recomend to be louder than 2 12" L7s. Please try to minimize the cost as much as possible i dont need to go way overboard. IM NOT RICH |
Silver Member Username: Dominirica012Charlotte, North Carolina US Post Number: 394 Registered: May-05 | the only JL set up that would beat the L7s in spl are the w7s but those are costly and they still might lose...well maybe some 15" or 18" w3s |
Silver Member Username: Mikechec9Chicago/atlanta Post Number: 404 Registered: May-05 | then i would look beyond jl. you will hit very hard with 2w6v2's w/500 watts behind each one. but they are NOT spl oriented subs. the w7's are. and they are both overated. i know it seems like anything less than JL is just not up to par, but trust me, that is certainly not the case. if you went w/ the rlp's (for example) you would be hitting hard and sounding much better than your boy as they are sql subs. i can go down the line to at least 8 brands/models i would chose before knabbing JL's. jmo |
Silver Member Username: Mikechec9Chicago/atlanta Post Number: 405 Registered: May-05 | but IF i did, i would only grab the w6v2's |
Anonymous | what is a rlp? |
Silver Member Username: LowdoseSt. Louis, Mo Post Number: 112 Registered: Apr-05 | They are SoundSplinters here http://www.soundsplinter.com/rlp_premium_series_12_and_15_inch_subwoofer.html Heard good things about those. |
