Underpowered??
JonK
What is the easiest way to tell if my subwoofer is being underpowered by my amp? Is there a sound? Can I use an ampmeter on the speaker terminals on my amp? I was just expecting alot more bass than I have now. I have one Infinity 12" subwoofer (reference series), 2 6x9's (running off of HU) and updated front speakers (Legacy, running off HU). And my amp is a POS that I bought off of ebay...bad choice...I know....Also, where can I find a decibal measurerer? Thanks in advance. Also, my car is a 1982 El Camino, so my cab space is very small...for this reason I expected it to be even louder too....
Username: Halby
Parsippany, NJ
Post Number: 57
you can tell that it is underpowered bc you arent gettting the bass you expected. Get a better amp.
Username: Halby
Parsippany, NJ
Post Number: 58
Also look up the specs on the amp you bought and compare to the Infity specs. If the RMS of the amp is much less than that of the sub than you are underpowering it.
JonK
my sub is 300wrms, but I have no specs on my amp except that it is "supposedly" 2000 watts by 4 channels and I have two channels bridged to my subwoofer. I don't know what the rms wattage is for the amp....Any suggestions?
JonK
here's what I could find on it...some advertisment from caraudiosupply.com:
Mitzu MPA-2201BK 2000 WATT Power Amplifier
Quantity in Basket: none
Code: MPA-2201BK
Price: $169.95
Shipping Weight: 8.00 pounds
Quantity:
NEW CHROME PLATED 2000 WATT CAR AUDIO POWER AMPLIFIER WITH FRONT AND REAR SUBWOOFER CROSSOVERS!
First of all, this amp is huge! It is much bigger than it appears in the photos!
The amp is absolutely beautiful with a mirror image chrome finish on the top.
This amp is perfect for subwoofers or can also be used to run your entire car audio system!
It can be used to power any size subwoofer or even mega watt 6X9 speakers!
You can even use two of the channels for full range door speakers and use the other two channels to run your subwoofers simply by pushing the subwoofer button to "on" making this a complete system amp all in one.
This amp offers numerous installation options.
This unit features:
MASSIVE 2000 WATT MAX POWER OUTPUT!
OVERLOAD AND SHORT PROTECTION
SCREW DOWN SPEAKER TERMINALS
GOLD PLATED RCA INPUT TERMINALS
ADJUSTABLE GAIN CONTROL
10-30 KHz
INPUT SENSITIVITY: Adjustable from 100m V to 1 V
BRIDGABLE 2 or 4 CHANNEL STEREO AMPLIFIER
2 OHM STABLE IN STEREO MODE
4 X 500 WATT MAX POWER OUTPUT! GREAT FOR 2 OR 4 SUBWOOFERS!
TOTAL HARMONIC DISTORTION LESS THAN 0.05%
SPEAKER LEVEL INPUTS WITH ADAPTOR INCLUDED
Stylish New ALL-BLACK AND CHROME Exterior Finish!
Username: Jaackdeth
United States
Post Number: 189
That's 2000 watts peak, and from the price and looking at it, no way are you getting that much in rms, which in what you are looking for, I doubt if that amp could even run that sub~
JonK
yeah, I know...I actually paid less for it about 60 bucks with the amp wiring kit...but it does run my sub...my sub shakes my windshield and rear view mirror, it's just not that "loud"...my mom's Pontiac Vibe seems to be louder...What would you guys suggest that's cheap for me to run my subwoofer?
