Anonymous | The car is 1995 4dr Acura Legend (full size sedan). I'm getting a pair of ALPINE SWR-1242D 12" Type Rs that will get 500watts RMS each. I am considering what kind of box to get, a dual band pass http://store.yahoo.com/csexpo/bp12dubacars.html or a regualar [OO] box with two 12" openings for the subs. Which kind would you get and why? Thank you very much to whoever takes the time to respond! |
Gold Member Username: GlasswolfWisteria, Lane USA Post Number: 8269 Registered: Dec-03 | if all you want is SPL, go with a bandpass box, but don't expect it to sound good.. just loud. for the loudest adn most musical balance, go with a ported enclosure for two twelves. by the way, don't use that prefab box you listed for type R subs. those boxes explicitly say on them not for use with high output subs, because that plexi window can't handle the pressures exerted by the subs.. and those type R subs are high output subs. stick to a solid 3/4" MDF box. No g@y windows. you'll get much better performance. |
New member Username: D33pPost Number: 1 Registered: Jun-05 | Thanx for the explanation and for the advice GlassWolf! Ported box it is. |
Anonymous | Thanx for the explanation and for the advice GlassWolf!!! Ported box it is. |
