To the many supporters of Athena here... How would u compare a kit including AS-B1, AS-R1 and AS-C1 speakers to the Micra 6 ensemble?
NetGeek
I would definitly go with the Audition Series over the Micra 6; the AS's are bookshelfs where the Micras are satalite speakers. The AS Speakers you mentioned above all have 5.5" woofers and 1" tweeters where as Micra's have 3.5 woofer and a half-inch tweeter.
You can get the B-1's & C-1's for $100 each and the AS-R1 for $75. For $275 you will have a system that will blow any HTIB out of the water.
