Does it matter if the speaker wires to the back surround sound speakers are at different lengths?
Username: Urlacher
Post Number: 41
I have very different length wires running to my back speakers. Will it make a huge difference or not? Thanks
Username: Artk
Albany, Oregon USA
Post Number: 1206
No. It's fine if the speaker wire to rears are a different length. I do however make sure that my fronts are the same. Why? God only knows I just do. My system sounds great and I'm sure yours will to. Go forth and hook it up.
Username: Jimvm
Louisiana U.S.A.
Post Number: 115
It will not; at least not one that you will be able to audibly discern.
