Alrighty guys i need some help i want two 12"s and i want them to give you that feeling in your chest when the bass hits not to where you cant brethe or anything, but yeah. i was looking into cvr's but im kinda not anymore cause i heard they are good subs but they wont do all that. but i dont want to spend alot of money either, so what would be a good choice for me, prolly buying a audiobahn a8002t amp or a a8000t. 400.2 or 800.1 watts rms at 2ohm. try not to give me opinions like get some 300 dollar subs. i want to try to stay under 200 for both together.
just get 1 kicker L7, it'll sound bad but from this post it sounds all you want is spl, or get some audiobahns, either way like thrush said you'll need a better amp than that, and i don't know who told you that about the cvr's because if you put 2 in a ported box tuned right, they pound, i bet if you looked around you could even find 3 cvr's for 200$, then (even tho i don't like hifonics) get a hifoincs brutus 1500xd or somthing(because they do produce high numbers for the $) the subs should be around 200, and the amp around 225
