Bronze Member Username: HemiboyPost Number: 64 Registered: May-05 | Ok day one and I got high as a kite (from the fumes) and im ready to say the he!! with it lol. Kinda like the fumes though. Take a look at the close up. How the he!! do you avoid that? Where the mat dries and its not laying on the base.. |
Anonymous | It looks like some cat threw up a hairball LMAO! |
Bronze Member Username: HemiboyPost Number: 65 Registered: May-05 | Yup, what a mess. What you see there is one gallone of resin. Its gonna take about three more gallons maybe 4. I might say fug it and make an mdf box. |
Silver Member Username: GeekbikePost Number: 343 Registered: Dec-04 | Is that just one layer? |
Bronze Member Username: HemiboyPost Number: 66 Registered: May-05 | about 3 ir 4 layers. I pulled my plug and the bottome is perfect. I think Im gonna just ship it out to a professional fiber glasser. This is messy and I think I fugged it up. |
Silver Member Username: RzarectorCoquitlam, Bc Canada Post Number: 483 Registered: Dec-04 | told u it wasnt easy dude hehe.. the fibreglass is no where near saturated enough.. u need to slop tons of that shite on with a brush and us a small roller to get it nice and flat.. those bumps and bubbles wont work so that piece is pretty much garbage.. try it again (if u want of course) do 1 layer at first so u can test methods with it( the more layers the harder it is to work) so basicly if u have afew bubbles on the first layer then u throw the next on it gets worse and worse.. u have to have a roller to make it work .. those small painter sponge rollers work good.. just make sure its all nicely saturated.. sometimes u will have to work it in with the painbrush . like pushing the end of the brush into the mat.. good to see u tried it though .. once u get it down itl go good..btw how did u lay the mat just curious? the easiest way to do it is to cut or rip 8 inch or so squares and just apply them together all the way around.. also i hope ur buyin the material at a fibreglass shop ..few more points...make sure u go past all the points of where u want to go .. u can always cut away material after.. i hope u used some sort of mold release! otherwise its gonna be fun getting that out if its strait taped to the metal.. lastly . why didnt u do the whole bottom? |
Bronze Member Username: HemiboyPost Number: 68 Registered: May-05 | It was taped to carpet but yeah it was a biotch gettin it out lol. I ran out of resin so i couldnt saturate that last little bit. I didnt do the whole bottom because I wanted 2 seperate chambers so I was gonna do two fiber box's. I didnt have a roller DOH!!. Im gonna do a blow thru. Cut into the bed of my truck and make a box so i can go big! Screw this lil sh*t lol. Thanks bro for the info |
Bronze Member Username: LowdoseSt. Louis, Mo Post Number: 92 Registered: Apr-05 | Yeah you coulda used some foil for a release here is a quick Tutorial its helped me in the past. http://web.njit.edu/~cas1383/proj/main/ |
Bronze Member Username: HemiboyPost Number: 69 Registered: May-05 | Oh and I tried to do like 4 layers at a time lol. Man I had stuff stuck everywhere (luckily no mess in my truck) but stuck to my arms hands (wore gloves) brush, container every fuggin thing. It was an experience, I can say Ive tried to glass something. Its just not for me. I might pay someone else to do it. But like I said before I want to go big and I dont think even a glass box will do what i need it to. I'd still be limited with subs due to mounting depth. I think I want to cut into the bed of my truck and build a mdf box that can house 2 15" solo x. |
Bronze Member Username: HemiboyPost Number: 70 Registered: May-05 | Thanks DD |
Bronze Member Username: HemiboyPost Number: 71 Registered: May-05 | This is what Im going to end up doing. http://dodgetruckworld.tenmagazines.com/forums/topic.ten-id-152732-s-blowthru_in stall_pics |
Silver Member Username: 54danny54Post Number: 712 Registered: Nov-04 | aye...will any fibreglasser do me a favor and make me a viddeo tutorial on how 2 fibrteglass lol, and send it 2 me through the mail il pay 10 bux lol email me for details danny__keen54@hotmail.com thats 2 underscores |
Bronze Member Username: HemiboyPost Number: 72 Registered: May-05 | Nix the solox Going to go with eclipse ti 15's. i might do one for noe then do another cut and box with another 15. ill just see what one sounds like first. I can get the box and one 15 ti for 800 bux. Ill cut the thing myself. Anyways this is what im dong Ill post pics as soon as its done! |
