Box stuffing
Username: Richierch
Post Number: 111
is box stuffing really needed and if so how do you apply it to the box(do you line the walls or just throw it in there)
Username: Thrushdtd
New York
Post Number: 236
line it is so it doesent hit the sub i would think. It is not needed but is useful for space saving because it can make a smaller box "feel" like a bigger one to fit the sub specs
Username: Mixneffect
Orangevale, Ca. USA
Post Number: 276
Stuffing can be applied in various ways:
Without stuffing, an enclosure will sound boxy/mechanical. This means that the walls will resonate/vibrate and add to the sound. This changes the sound, for worse. Yes worse. Just because it adds volume doesnt mean it is better. Hollow, boxy, boomy sound is something to stay away from.
When you add "lining" (not to be misinterpreted as stuffing) it helps reduce the hollow hall effect, or boxy sound, but it will not do what stuffing does.
Stuffing is loose filling that adds opposition to the driver by making the air pressure change and thus a larger wavelength may be created in a smaller enclosure. Larger wavelengths result in lower bass. Although you get extended lower range it is at the cost of efficiency, so it will play a lower note, but not as loud.
The more stuffing you put in the box, the higher the air pressure will be. Sometimes in an empty enclosure the pressure will bounce back into the woofers cone and cause distortion. When lining/stuffing is present, it will help minimize rebound.
Username: Richierch
Post Number: 113
ok so i have a box that is the right sq ft without stuffing when i put the stuffinmg in will it mess that up
Username: Richierch
Post Number: 114
Orangevale, Ca. USA
Post Number: 285
A sealed box usually requires to be stuffed fairly dense. A ported box should be minimal (lining on walls, loose stuffing, and or both).
Stuffing will not take away box volume unless its too dense in a ported box.
Username: Richierch
Post Number: 115
so if im making a sealed box where should i put the stuffing...and i assume we're talking about poly fill
Orangevale, Ca. USA
Post Number: 292
Yes, polly-fill. Just insert itside the box. You will need more than one bag. Fill the entire box with polly-fill except leave a little breathing room for the woofer (keep at least 3" clearance). The stuffing should be dense enough to stand up on its own.
For sealed boxes sometimes they recomend stuffed tight. Make sure that it bounces back after you put gentle pressure on it (like a pillow). That should make your suspension very crisp.
Username: Rmzracer
Bentonville, Arkansas USA
Post Number: 11
in a sealed box i believe its about 1lb of poly fill for every cubic foot.
Username: Subfanatic
Ky
Post Number: 4437
and that will add 10 percent
Username: Rmzracer
Post Number: 13
so 4lbs per cubic foot since it can increase up to around 40%??? thats a lil over kill man if im understandin.
Username: Richierch
Post Number: 118
ok thanks
do ported boxes need stuffing ?
Username: Hardhittinbass
Pittsburgh, Pa Usa
Post Number: 31
say if i got a ported box with 3.85cu ft will it make it sound better an more bass
ThatGuyYouKnow
if its a tuned port you wouldnt want to mess with that. and hes right about 1cu = 1lb of polifil. best $7 ever spent. My enclosure was Sealed.
