New member Username: CklukasCoeur d'Alene, ID USA Post Number: 8 Registered: Jul-05 | I want a top of the line car security system. Any suggestions on either Viper or Clifford would be greatly appreciated. |
Silver Member Username: JeremycGermany Post Number: 763 Registered: Jun-04 | Actually both are great alarms. I perfer clifford, since I have been using them for years, and have never had a problem. Others really like viper. Either way you are getting a great peice of equipment. I don't know what you want option wise, but I have the Clifford intelguard 750 with the intel start module, and really really love it. www.clifford.com/g5/sec/default.asp#intelliguard750 www.clifford.com/g5/access/default.asp#intellistart |
Bronze Member Username: CklukasCoeur d'Alene, ID USA Post Number: 16 Registered: Jul-05 | I was looking at the Avant Guard 5. Any info? Does it come with all the remote start necesities? Do I need to buy anything else other than the AG5 system to use the remote start? |
