Who knows a good amp with a bass knob
Username: Ihaveasystem2
Post Number: 23
Im looking for a good amp around $100.00 that has a bass knob I want a amp around 300 watts 2 channel thanks
Username: Glasswolf
Wisteria, Lane USA
Post Number: 8075
good amps don't need bass knobs, and they cost more than $100.
sorry
Post Number: 24
well my friend wants one with a bass knob and he saw Punch 3002 searies amps and he wanted one like it a little cheaper
Username: Iowahawks19
Post Number: 263
go used, it's your only hope, look into brands such as MTX/JBL also
Username: Glasswolf
Wisteria, Lane USA
Post Number: 8093
see the problem is a bass knob can and usually does add distortion and drives the amp into clipping which can damage your subs.
that's why people avoid using bass boost circuits on amplifiers.
as for 300 x 2, does he need 300x2 @ 2 ohms or 4?
can he use a 600w mono amp?
2ch amps are usually class AB and more costly per watt than a class D mono amp, and both work fine for subs, where the class D is cheaper, runs cooler, and takes less room as well as draws less current to make the same power.
is he using a pair of single 4 ohm coil subs?
