Isaac, this true?
Username: Blitzedeclipse
Post Number: 43
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D5789821466&category=18797 %26
2400 peak? would that be stable for a dual 2ohm l7 15"?
Username: Iowahawks19
Post Number: 281
yea it says right on that page "725wrms@2ohm"
isnt the L7 750wrms??? it should be fine, even though i don't know why you would get a nice SQ amp and get a SPL sub, thats a very nice amp though
Post Number: 44
Yeah, well this would be my first actual good sq amp, I want to try it out, plus that amp will actually push out 1200 true watts right?
Also, what about the orion 2500D, will that be a little bit too much for an l7?
No the L7 is 2000 max, 1000 rms.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 8189
STOP USING PEAK/MAX RATINGS!!!
stick to RMS for speakers and amplifiers.. Peak means nothing
Username: Alias747
MN
Post Number: 473
If the L7 is 1000 watts rms, you should be ok with the 1200D. You will be giving it a little too much power, but that is fine, just watch the gain.
And yes, a 2500D would be WAY too much for an L7, it would be a little too much for 2 L7's!
Username: Carguy
Post Number: 3565
If you have HO alternator and plan on upgrading subs in the future, 2500D is a better choice.
Just cause a amp is 2000w rms, it doesn't mean the subs will get full power as soon as it's on. The volume control will limit that.
