Stripping the LCD monitor?
Username: Jeze
Post Number: 38
I'm curious to know how I can strip the white paint which label label my LCd monitors. I'm trying to remove the Make and model from the screens which seem to be painted on.
Username: Illuminator
Post Number: 883
Scratch it off? It's probably worth doing if you don't want the brand name showing...
Username: Jeze
Post Number: 40
With a razor blade?
Post Number: 886
Sure, maybe you could sand it a bit when you're done, though I'm no professional at scratching labels off things...
Username: Climbamtn
Seattle, Wa Usa
on white monitors we use the green scrubbys like for washing dishes. doesnt work so well on black or painted as it chews through paint to the plastic. but sounds like that is what you need.
