Matching amp to sub, need help.
Username: Jfo68106
Post Number: 7
- Would the Alpine v12 MRD-605 mono amp (which runs at 400x1 rms @ 4ohms, 600 x 1 rms @ 2 ohms) be good to power two Alpine type-R subs (run at 500rms) ??
- What's the big difference between the type-r 10 inch and 12 inch if both have the same power rating ??
Thanks everyone.
ihaveasystem2
I would not suggest a Alpine sub now I dont know about thair amps but a 10" sub has a higher bass than a 12" sub the 12" sub is the best overall sub to get
Username: Jfo68106
Post Number: 9
- But would da Alpine v12 mrd-605 with the specs I listed above power two type-R's good ?
- I would like to know the answer to the question above, but I also would like to know any other suggestions for subs and matching amp around that same price range. Alright thanks.
