Sony Trinitron Television - Model KV-1714
Does anyone know if this model originally came with remote control capabilities? I can't seem to get a Universal Remote to work with it.
Any info would be appreciated.
Username: Samijubal
Post Number: 1139
I don't know how old that is, but virtually all TVs made within the last 15+ years use a remote.
Username: 4u2ges
This model is 1979. What kind of tuner it got? Is it the one with 6-12 presets you manually tune? Then you're out of luck; there was a special Sony remote for that, which no "Universals" would substitute.
Danslamarde
Does anyone know which type of universal remote control will work for an old Sony Trinitron kv-13tr14 TV? I've just bought a Sony universal remote control (rm-v202) but am unable to access the menu with it (only vol or channel).
Thanks a lot for any info
i cant get it off of sleep mode can you help ??
sony trinitron kv138or
