Archive through July 15, 2005
Enrique Iglesias
not true.........Dishnet moves only a few channels at a time only on Wednesdays. So its expected that the transition will be completed until early September. Of course by then there will only be a couple of channels left to watch.
Until now we have only lost the Adult and a few Cinemax and Starz channels.
ron10
codes please!!!!!!!!!
Nina
Key0= A1 8B 3F 9C 3C 90 94 8F <----7/6
Key1= 40 B2 B9 7A C2 C1 53 75
Rocky3
Thank you Nina sweety.
I love you.
P.S. Damn, they moved PLBY channel.
Username: Mikeylude
How do you find PLBY channel again?
the 2 starz channels and plboy channel are blocked. Keep away from bad stuff for your own health.
Username: Mikeylude
I have a rookie question, lol!
rocky3, wrote they moved the plby channel, so i thought that all the channels i lost until now can't be recovered
so when you lose a channel is it because it moved and you can find it again by doing a channel scan or is it just blocked, period and not recoverable until another program comes out???
clouie
I have lost all channelssssss anyone else?? N2 or what??????? just new code.. help thankssssssss
so once all the channels be moved to NG2, what will happen to out NG1? are we going to have some kind of programms or keys so we can crack and gget N2? anyone with some latest info?
your sat receiver will be useless, but some people claim that they hacked N2. Be patient.
Username: Maple_leaf
Post Number: 486
If n2 is not publicly hacked then you will only have true fta channels.
Right now the only fta that has a way around it is the dream box units.
i dream of box
what is a dream box unit?????
rosered
when I enter new codes - do I always need the 00 and 01 new codes or will just the 01 new code work if that is all that is posted?
Username: Supersuzy
Atikokan, Ont Canada
thanks for the codes
what exactly does the "active" key mean?
I'm new at this.
eral
active keys are the new keys for that day
equip your dish with double LBN to be able to watch all channels located at 110 and 119. They are many including several PPV and sport channels.
bunki
I have entered the new keys for the day, but still get the "encrypted or bad channel" message. system worked fine yesterday.
Username: G_rod
Does anyone know if there will be a fix for the Bell sat F.T.A dish once they all go N2? If so will it be a key code or will I have to take my receiver to someone to get it fixed?
buffalo
bunki...do a reboot/reset whenever U have any problems with FTA and/or AFTER U change the keys...and there were new keys yesterday..
DISHNET KEYS Current
07-07-05 01:00pm EST
Key0: A1 8B 3F 9C 3C 90 94 8F
Key1: C4 82 37 AA 5B C2 2D E5 ** Active
Here's a reboot/reset...BACK of receiver,power OFF,wait 2 minutes,power ON,go to channel 300
Gerrad...there is no N2 fix now,so don't hold your breath or exopect answers about the totally unhacked and obvious unknown.
sivle
to buffalo
U know your stuff.
good work.
sivle
Posted on Friday, July 08, 2005 - 10:55 am:
to buffalo
U know your stuff.
good work.
He should LK has been around a while and good for this site.
Niagara Falls
still can not get it to work. Have tried what Buffalo has said. Help
9055
Anytime U have problems bring the receiver back to factory default,load the factory bin, then the lastest bin, always reboot the receiver after any change. make it a habit and u won't have problems.
Niagara Falls
sorry I'm blonde what is the latest bin...then I;ll try it Thanks
haleys comet
latest bin for what receiver?..and just what are you exactly doing and done...and is this a new problem or an old problem...are U familiar with FTA...have U ever loaded bin?...done a scan before?...which satellites are U using?...whats your equipment and ALL hardware?
MONSTER CHEF
I have the pansat 2500a i lost echostar 7 & 6/8 the receiver indicates no signal and no transponder. can i please get some help. and thank you so much.
irvingkarel
new dish keys anyone?
IK
irving
chicago
Monster...provide much more info...no signal sounds like dish is not aimed correctly is a possibility,amongst many others...like bad cables or connections or disque switch
07-08-05 04:30pm EST
Key0: C7 81 C8 80 A5 61 54 59 ** Active
Any time you lose the signal turn off the receiver from the back or unplug it, wait for a few seconds then turn on again.
Munchyman
c7 81 c8 80 a5 61 54 59
789456321456987
Thanks people for the codes...
Irving
I am having a dish problem.starz and other channels are blocked. what are the correct blackout keys to open all channels
chicago
Anytime AFTER U do a key change and/or have any problems do a reboot/reset..
Reboot/reset is ...BACK of receiver,power OFF,wait 2 minutes,power ON,turn to channel 300..
Irving
chicago,
at the bottom of your grid are the blackout keys
can you give them to me,please
eral
hashHU,com also has new key code for dishnet when codes go down.
Username: Shandee22
Post Number: 22
i have a fortec ultra and i put thoughs codes in and it said it's scremmbled or bad channel
chicago
urbabe90
i need help i put the code but the TV still wont work wat should i do? HELP 911....lol
need new key codes down agian.
Lagputter
Use an AUTOROLL PROGRAM(ULTRABAR)and you want have to type in those pain in the a$$ key codes in.
latest keys @ http://dsses.farvisa.net
chicago
monster ...same reply...wind can move dish...cable and connections go bad..U need to check those things out first...then apply the factory bin and start from scratch.
Monster Chef
chicago ....I checked out the dish looks good i replaced 1 cable and checked all connections all good. when i turn on the reciever it says on and im in the language menu i click on english then im at satelite setup menu im getting 25 to 30% and zero % on quality and im stuck at that point.also ehcostar 7 6/8 are not on the sat. menu but i see ehco 7/ku 8/ku and so on.i downloaded some bin files to my computer but im not able to download files to reciever i dont know how. and as for the factory bin and start from scratch im lost sorry.my friend who set this system up has passed on due to a motorcycle accident. thats why im here asking for help please.if you want a email address i can do that.thank you very much.
Username: Ishelou
Hi All, i put the key ..is good..is watch almost all chanel except arabic chanel ... please can someon help me . hwo i can watch the arabic chanel.. thx... Upload
Username: Ishelou
HI.all, plese can help for watch arabic chanel,
i put the key is good .but only arabic cahnel can t watch tem..please help.... thx..
mtarrazo
I need some help.. I enter the code and every channel says bad or scrambled channel what can i do to correct this? please
chicago
arabic channels are gone to nagra2...must subscribe to get them now..
bad/scrambled channels ...do a reboot/reset...BACK of receiver,power OFF,wait 2 minutes,power ON,turn to channel 300
monster..based upon your info,your dish is not aligned correctly...U need minumum 60-70 %
Username: Ishelou
thx Chicago for your reply.
bunki
Chicago.. how do you change the channel to 300? I seem to be missing something here. Also what is autoroll and how does one get this to work on your fortec?
Username: Joany
Post Number: 7
new keys 00
c6 81 c8 80 a5 61 54 59 Here you go guys!
what gives are we done
Username: Titi
Denver, Colorado Usa
new fortec key
Username: Titi
any one has new key for fortec thank you?
sivle
is there a way to get RAI TV on the pansat 2500a ?
gcmld
Where do you get free updated autoroll like the X-87BL_050519_105_api for the Pansat 2700A?
I still have the old software that I paid for, but it's useless.Appreciate any suggestion. Thanks
chicago
If U paid for any software then U are a fool...its always been FREE at ALL reputable DSS sites...there are threads here which list them..
BTW...old software is NOT useless...it will always work!
I tend to think U are not a real FTA user based upon your post..just someone who wants to talk...any FTA owner knows what U posted is 100% untrue or makes no sense.
dereker
does anyone kno the new code for pansat....left on sunday...
dereker
for the pansat2500A PLEASE wuts the new code
keys @ http://dss.br.nu
Username: N_enterprises
SATELLITE SOFTWARE CD WITH EVERYTHING YOU NEED
NO NEED TO ASK ANYONE AT ANY FORUMS, NO ASKING FOR KEYS, THERE IS A PROGRAM ON HERE TO GET
KEYS YOURSELF, NO ASKING.
DIRECT CONTACT WITH MYSELF AND LOTS OF HELP. HOPE YOU DECIDE TO GET THIS CD AND MY
SUPPORT. I WILL GIVE PHONE SUPPORT AS WELL AS EMAIL SUPPORT TO GUIDE YOU STEP BY STEP TO GET YOU RUNNING.
This CD contains the automatic key finder to download to your receiver, and never input
keys manually again. It automatically finds the new key when channels go blank. Everytime.
Also included are the programs of Getkey and Keymaster, to bring up the latest keys in
case you need to input keys manually. Just in case.
THIS CD also contains INSTRUCTIONS and SOFTWARE for the PANSAT 2500A FREE TO AIR RECEIVER!
AND NOW OTHER RECEIVERS LIKE THE PANSAT 2700,PANSAT 3500, 5000HC, COOLSATT 4000, FORTEC ULTRA, DREAMBOXX, PANTEC, ARIZA
CYCLONE AND BLACKBIRD.
EVERYTHING IN ONE PLACE, EVERYTHING ON ONE DISC!!
Get the channel lists you need to see Dish Network the same as the others do like this:
160 MTV
161 MTV 2
170 Nick - East
171 Nick - West
172 Disney - East
173 Disney - West
174 Toon Disney
180 ABC Family
181 PAX TV
182 Discovery Channel
260Trinity Broad.
261 Eternal Word
262 Sky Angel
264 Wisdom
300 HBO - East
301 HBO2 - East
496 PLAYBOYE -ESP
Get all Dish Network channels, wide open, for free!! Cool!!
YOU WILL ALSO GET HOW TO VIDEOS AND STEP BY STEP PICS OF SCREEN SHOTS OF MENUS ON TV
SCREEN ON HOW TO PROGRAM YOUR RECEIVER. COOL.
GET ALL OF YOUR QUESTIONS ANSWERED HERE BECAUSE I WILL GIVE 'FREE PHONE AND EMAIL SUPPORT' FOR YOUR SOFTWARE THAT YOU RECEIVE!!
CONTACT ME THRU MY EMAIL AT THE LEFT.
I HAVE SOLD OVER 200 OF THESE CD'S ON EBAY,
NORTHRIDGEENTERPRISES IS MY USERNAME ON EBAY, PLEASE CHECK MY FEEDBACK, AND YOU WILL BE UP AND RUNNING WITH DISH NETWORK.
A-Diddy
New key pretty please..
keys at http://dss.br.nu
Username: Shandee22
Post Number: 24
new keys please
chicago
Username: Vasu02
Any one has new key for Dish network-fortec Lifetime Ultra
Thank you?
KeyMaster
JUL-08-2005 04:30pm EST
K-$hepps
Hey folks. I can't get any channels. I've loaded the new autoroll bin and everything comes up scrambled. Tried manually entering the keys and still no love. Any suggestions?
Username: Jerryw
Key Largo, FL
What receiver do you have and which do you like?
I understand some can use a broadband connection to receive keys. Is that right?
And will nagra2 make the ones out obsolete?
Jerry
Username: Jerryw
Key Largo, FL
My queston not just for chicago. I am asking anyone who has a working rig right now.
Jerry
Username: Supersuzy
hi bert
these are the codes
key00 c7 81 c8 80 a5 61 54 59
Username: Estrado
please help me my fortec star is dead no more bellexpress if some one can explain how to give a new live to my fortec please give me a hand thanks estrado
Username: Canadianpig
Key1: 18 05 94 5D 50 E7 A1 C8
Benjamin Gustofe Henward 3
alrite so dis is wut happen i buy de centilimn processer but it is uncompatible wit my Y2J modem which blocks out my capablity to my phenix fax machine so my fuse box gets a 3.1 combustion sequence which uploads unwanted virises to my centilimn processer which completely rots away my anxation of pordirico fire upload, so can any 1 help me please if eny 1 can get me an answer i will be most thankful
ROCK5
KEY01=18=05=94=5D=50=E7=A1=C8=ACTIVE
Username: Luvchocolate
Montreal, Quebec Canada
WHAT IS AN AUTOROLL????????????????????? HOW CAN I DO ONE??? Please i need help!!!! i'm newbie...
arabic channels are achenged their frequencies.Try searching the new frequencies.
Username: Supersuzy
hi bert
the new number key01 18 05 94 5d 50 e7 a1
g off
Hey guys I wondering if any one might be willing to help me out. Like a dumb a$$ I accedently erased my factory settings now `when I turn my panset box it goes directly to the select a languge and I can't go any further could some one lend a hand to get me back up and running?
I would really appreciate it
Username: Ramadan
new key
key01
good luck
Username: Ramadan
07-14-05 1:00pm EST
Key0: AC 7D CF 36 D5 32 9B 5D<--Active
tropics420024
new keys?
Username: Estrado
i need to now how can i get back my bev with fortec star 5900 with a titanium card please i got the programmor and i try whit all the code that you give and i only got cbc nothing else thank for the help estrado
KRAZYONE
how do i get roll over keys?
keys anyone? thank you in advance
deft
damn.... did anyone else just lose everything but the ppv guide channels?
New keys 7/15/05
Key 00 = AC 7D CF 36 D5 32 9B 5D
Key 01 = E9 FD 53 DE B5 37 FC 44 ACTIVE
__________________
Rocky3
Anyone has the new keys for dishnetwork?
Thank you.
Rocky3
Anonymous you are the man, no doubt.
Keep posting these new codes everytime.
Thank you.
pinga
Hi,
i don't have sound in my TV with the new key.
Can anyone tell me what's happening?
pansat master
pinga try pressing mute
pinga
I tried with the TV control but doesn't work,do you have another solution please? I thing it's something in the signal maybe....i can't fix it
KEY 00 - AC 7D CF 36 D5 32 9B 5D
KEY 01 - E9 FD 53 DE B5 37 FC 44
pinga
I don't know how to have sound in my TV with tihs new key,something happened because i have sound when i change to cable,but,with the Dish Network signal i don't have sound....HEL PLEASE!!!!!!
pinga
I'm still having problems with audio in teh dish network signal...PLEASE HELP!!!!
pinga probably you muted the sound from the satellite receiver without knowing
Pinga
How? i've been trying to find where is the mute end i only found the mute in the remote control,then,i press it and nothing happened.
Thank's Anonymous for you help,may you can find the solution for me,i have signal buy i don't have audio....i'm guessing that the problem is because in the signal with this new key i don't have power to receive audio....maybe
Hi guys/girls:
I am trying to change my express vu over to dishnet. I have all the info except where I am to enter the provider ID.I do not know what numbers to put in. Can you help?
can't tell you
Try 71 01
