Username: Tylermoncrief Post Number: 53 Registered: May-04
Wednesday, July 13, 2005 - 02:14 GMT Yo...I got 2 Kicker CVRs 12" 2005 4 Ohm Model Ok, I wired my speakers up to be 4 ohm I got a KAC-7202 amp Its bridgeable I bridged the speakers on the amp 2 on 1 positive 2 on 1 negative For some reason it keeps blowing the fuses Now on the kickers there're 2 dots on a negative and positive. and the other 2 there isnt any dots I wired the 2 dotless toghter and wired the positive dot to the negative dot on the other speaker & Vice versa the negative on the other speaker. Fuses keep blowing. Know what the problem is?
Username: Tylermoncrief Post Number: 54 Registered: May-04
Wednesday, July 13, 2005 - 02:17 GMT Correction : Kenwood KAC-7252
Username: Tylermoncrief Post Number: 55 Registered: May-04
Wednesday, July 13, 2005 - 02:19 GMT Fuse that blows is a 40a fuse..not the fuse from ampkit to the battery
Username: Tylermoncrief Post Number: 58 Registered: May-04
Wednesday, July 13, 2005 - 03:21 GMT Any Help?
Username: Carguy Post Number: 3529 Registered: Nov-04
Wednesday, July 13, 2005 - 03:54 GMT Are you saying the fuses on the amp is blowing? Does it blow instantly or after a delay? Does it blow with no speaker and rca connected? What dots are you talking about? Is it on the sub terminal? Do you have a picture? When amps blow fuses, it's due to power/signal overload. Something's shorting out the output terminals on the amp. Check all your wires carefully.
Username: Tylermoncrief Post Number: 64 Registered: May-04
Wednesday, July 13, 2005 - 04:02 GMT Do you have AIM...I need faster responsed AIM : TylerMoncrief
Username: Carguy Post Number: 3532 Registered: Nov-04
Wednesday, July 13, 2005 - 13:16 GMT Sorry, I don't have AIM nor MSN chat.
