Bronze Member Username: ShutterleftopenColumbus, Ohio United states Post Number: 84 Registered: Apr-05 | well right now i'm running 2 12" MTX 6000's in a sealed box powered by a 1000w max cyclone amp. it's horrible. surprisingly the subs still hit pretty hard. with only like 200w rms powering them. i'm on a really tight budget. but i have time to save up. what is a good amp i could use that's maybe 300-600 watts rms for a decent price? |
Bronze Member Username: ShutterleftopenColumbus, Ohio United states Post Number: 85 Registered: Apr-05 | anyone? |
Silver Member Username: Dominirica012Charlotte, North Carolina US Post Number: 253 Registered: May-05 | jbl 600.1,KICKER KX600.1,MTX THUNDER 6500 D all are good amps that will power your subs better than that cyclone amp of yours...you can get all those for less than $200 on ebay |
Silver Member Username: Marley289Post Number: 193 Registered: Nov-04 | get the mtx 421d, it should power them just fine...or get the mtx 801d, but be sure to check the rms on that one first im not too sure if its too much for those subs. http://www.cardomain.com/item/MTX421D http://www.cardomain.com/item/MTX801D |
