Silver Member Username: 54danny54Post Number: 650 Registered: Nov-04 | How do u tell if the sub wants 2 be ported or sealed lol...i know u can use 2 different T/S's and il copy and paste the answer in a document so i wont forget lol |
Bronze Member Username: LettoMilwaukee, WI Post Number: 72 Registered: Jun-05 | "Efficiency Bandwidth Product (EBP) EBP = Fs / Qes 50 or less = best used in a sealed enclosure. 50 - 90 = flexible enclosure options. 90 or greater = best used in ported enclosure. -OR- Qts < 0.30 - ported Qts = 0.30 - 0.50, use ported or sealed. Qts > 0.50 sealed" Thank Glasswolf for this: |
Silver Member Username: Alias747MN Post Number: 433 Registered: Apr-05 | http://www.bcae1.com/spboxad2.htm Use the calculator at the bottom of this link, enter all the data and it will tell you what kind of enclosure is best for that sub. |
Silver Member Username: 54danny54Post Number: 651 Registered: Nov-04 | Thanx both yall...i needed it for winisd lol |
