Echo7 not working, Echo 6,8 working NEED HELP
DenisItsMe
HEY guys, am having trouble here, everythnig work fine but when i ran a satelitte scan on my echo 7 , all the channels it carries doesnt work, also the quality is at 53% but the level is at 0
also i want to put everything to default i was sorta messing around with it, like fta and that stuff i dont know what the DEFAULT is
can i have help fixing this please
what do i do run a sattelite scan agian
help ECHO 7
sol
looks like your satellite is off angle...maybe some adjustment will do.
Username: Slo_hand2
Post Number: 12
what system do you have first of all to set back to default, if it is a pansat there is a restore to default under user as far as the echo 7 is concerned what type of lbn are you using, look for a satfinder here on this site
Denistsme
thnks guys for the reply
actually i just realized something, my echo 7 channels work but the PPV channels dont
just my normal PPV channels ECHO 6,8 work BUT PPV echo 7 dont
i try adjusting doesnt work, also dont think it maters because some channels work just ngot the PPV, this might be happening to u too guys chek it out
and the lbn am using,,,,,,dont know what lbn is lol
