why didnt autoroll work this time? I have a 2500a pansat and I had to manually input these keyes this time. Do I need a new autoroll ? Which ones better for pansat?
metallica rules
thanx anon
Wendy Wilson
are these keys safe for an clone black-bird?
that key is not working for me
melonman
they working fine for me simce yesturday
melonman
btw......what you peolple doing now theres no adult channels
LK
These keys work fine ...and are for Dishnetwork and ALL receivers,including the BB...how they are installed varies from receiver to receiver..
what do U think people will do for adult entertainment?..must buy or rent videos, or subscribe it if U want it..
HELP I SPENT ALOT FOR SOMETHING THAT DOESN'T WORK I THINK I HAVE THE WRONG KEY CODES MY CODES ARE FROM APRIL-18-05 ARE THOSE THE CURRENT CODES
PLEASE HELP THANK YOU
rgthetjhs
how do you input these codes...i have the new blue jay what does key or aux mean?? as well as active...i was told just to insert code and will work but this is not the case any help??
LK
U need a manual...
dertrtgr
where can i get a manual ...my blue jay receiver book does not say anything about inserting code
LK
borrow one from the red sox..
dggdd
what is red sox and where do i get it??
Hi. I imput those new key thereafter a data is beign downloaded pop ups(then enter data?) What data? and nothing happens. Could some one help me. Thanks
LK
wait for it to COMPLETE...read the How to's here..
LK
How to change Dishnet keys: 00 or 01
Pansat receivers................
press menu
go down to parental controls, and press OK
press down arrow and enter 0000 thats 4 zeros
now go down to nagravision and press ok
now press the right side arrow next to the ok button 11 times until it says dish network
now press the down arrow 1 time
key number should read 00 now
using the buttons on the remote (number buttons, To type the letters into the new keydata, press the appropriate button on your remote: Audio = A, Info = B, Signal = C, Pause = D, Sat = E, EPG = F)
set the key to whatever the latest key code is 8A C4 96 93 EC 79 9D 57 ....(example only)
now press the ok button!
then press exit 3x to exit the menu
Lastly, on BACK of receiver (not remote)..power OFF,wait 1 minute ,power ON..this is a reset
This is how to change your public keys when needed, these instructions should work for both 2300 and 2500 pansats. ............................................................
Fortec key change method
1)With receiver hooked up to TV and satellite: 2)Press MENU on the remote control 3)Then right side arrow to CHANNEL EDIT 4)Go down to CODE, and press OK, and enter 1010 (could also be 1668 or 1688) 5)Then right side arrow to turn OFF, KEYCODE FUNCTION 6)Go to NAGRAVISION and press OK 7)Now press the right side arrow next to the OK button 11 times until it says ((DISH NETWORK)) 8)Go down to KEY Number, then right side arrow to set to "00". 9)Go down to Key Data and enter the latest KEY with your remote control. D5 6F BB 83 00 D8 B0 4E ...(example only) 10)Press OK, "you will see the STORE button blinking, when it stop you know that KEY Number "00" is saved. 11)Go up to the Key and Go to the right "1 time" (that will change key 00 to 01 12)Go Down and enter latest Key 01 change ..11 B1 AA A7 8B 9E 45 8B (example only) 13)Press OK, "you will see the STORE button blinking, when it stop you know that KEY Number "01" is saved. 14)Press EXIT once. 15)Then right side arrow to turn Code back "ON" and enter "1668" then EXIT, EXIT. 16)Lastly, on BACK of receiver (not remote)..power OFF,wait 1 minute ,power ON..this is a reset
Fortec buttons to use for letters
Sat=a info=b tv/radio=c pause=d ?=e
khiditdo999
help, whenever i enter the keys in for my pansat2500 and store it, the code always changes by switching places, and it keeps doing that no matter how many time i've tried plz help me anyone
where do i get the new codes when the channels get scrambled. pliz help
does anybody know how to crack codes for payTV. HOW DO I DO IT IF I HAVE FREE TO AIR DECODER?
LK
codes and instructions are inside the decoder ring at the bottom of the cereal box..
sat went down yesterday. need keys. help.
what's up with n2? encrypted signals now? can't locate. any alternatives to obtain blocked signals
Hi, i have a fortec star lifetime ultra What i want to know is to find the key. Where do I go on the we to get it
to get current key i use key ripper its free current keys F8 77 B9 93 B7 CF EF 5C 0E 96 1C 61 10 77 D3 38
pimpcess
hay...! wats da latest keys for dish net! SOMEONE PUHLEEZE REPLY! I REALLY DUNT WANNA MISS MA SHOW TOM! THNX!
need help disberately
hay mi dishnet juss went crazy tha screen is jumpin all ova the place PUHLEEZE TELL ME DA LATEST KEYS FO DISHNET ND HELP MI STOP MA SAT FROM JUMPIN ALL OVA A PLACE!I EVEN TURNED IT OFF FROM THE RECIEVER AND IT STILL DOES THAT CRAP!!!!!!!!!
The Irish Culchie!
Here ya go...
KEY:01
77 C4 B3 74 E0 6B 15 28
hi does anyone know the active keycodes for satellite, for july 9
