New member Username: HeadutterPost Number: 1 Registered: Jul-05 | My son has a 98 Cadillac Seville w/a bose delco system. He wants to add subs and an amp. He had 2 Mts subs and a Kenwood amp that wasn't enough. You could only hear it a block away. He had it in a sealed box facing the rear. The back seat is mostly hard plastic in the trunk. What can he get for great 3 block away thump for under $1000.00. I sugested he pull back the cloth and cut as many holes in the back window deck as possible and blow the speakers up in a ported cabinet. Is it also true that say a 3" voice coil will give more thump and a quicker return than a 1"? |
Silver Member Username: Dominirica012Charlotte, North Carolina US Post Number: 195 Registered: May-05 | he can get a 15" or 18" RE XXX for about 400 bucks...he'll be heard for more than 3 blocks if set up properly |
Bronze Member Username: Big_osoPost Number: 84 Registered: Jun-05 | very true then you can spend the rest of the money on a good amp to power it and a enclusure |
Silver Member Username: 54danny54Post Number: 547 Registered: Nov-04 | yes david get him a resonant engineering XXX 15 inch with a hifonics brutus 1500D amp... www.reaudio.com for the sub(i think i forgot lol) and www.woofersetc.com for the amp |
Silver Member Username: Dominirica012Charlotte, North Carolina US Post Number: 196 Registered: May-05 | youll need something a bit more powerful..that hifonics is slightly overrated and the XXX takes 1600 watts so you should get a Hifonics Brutus 2000D(i think thye have this) off ebay then youll have about 200-300 dolalrs left for a custom enclosure |
New member Username: HeadutterPost Number: 2 Registered: Jul-05 | Thank you all. Keep those cards and letters coming. He seems to think he wants two 12's instead of one 15". Second, what about the size of the voice coil relative to the punch and recovry and blowing it staight up throught eh rear deck? |
Silver Member Username: Dominirica012Charlotte, North Carolina US Post Number: 206 Registered: May-05 | wtf...well i didnt get much of what you said but w/e...trust us when we tell you that he only need one 15" XXX...this will blow his old system out the water these are some very well built subs...but if he has to go 2 12"s he could just get 1 18" its around the same surface area and that will have crazy bass |
