Fiberglass box
Username: Mustang_guy
Post Number: 44
would it be worth the money to get a custom made fiberglass box??????
Username: Hemiboy
Post Number: 46
It'd more way worth the moeny if you do it yerself. Looking at 100 bucks give or take a few.
Post Number: 50
is it easy or do u know??
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 431
not worth the trouble imo.
Username: Matt12490
Benicia, California
Post Number: 73
yeah i hear its pretty hard and takes a long time... i would say its not worth it
Username: Geekbike
Post Number: 309
Unless your space is limited or you plan to enter some shows, it isn't worth the time and effort.
Post Number: 51
oo ok i didnt thnow the first thing about it..
Username: Mixneffect
Orangevale, Ca. USA
Post Number: 206
Fiberlass has low density, and therefore it will sound boomy. It will actually be annoying if you plan on using it for SQ.
Username: Tbolt
Collipark, GA
Post Number: 46
what about plexiglass. is it a better choice or just as difficult.
Orangevale, Ca. USA
Post Number: 212
Stay away from anything that is low density, and resources that resonate high. Try to use resources that are low resonance, because that way you get sound out of just the speaker, not the box. If you get box resonance it sounds boomy, and mechanical. In other words it doesnt sound like the real thing.
Plexiglass is junk for building speaker boxes.
Username: Hemiboy
Post Number: 47
I wasnt really thinking, I have very few options. But if you had other options then fiber then that is probably the way to go. Im just talking sh*t cause I am gonna have to build a glass box if I want more airspace. Plus, misery lubs company ;)
