New to this stuff so give me a break. I have 2 12" subs that are 4 ohm's each. I have done some research and found that i can wire a mono 2ohm amp to both to make 2 ohm load on the amp. I was wondering are there any other types of amps(example 2,4 channel) and different configurations to where they will be more efficient or powerful.
the lower the ohms the more powerful the amp gets(ex. 4ohms-400watts,2ohms,800watts,1ohm 1200watts) somthing along those lines, also are your subs DVC or SVC, and i would go a mono amp for 2 subs
mike1
can u tell me any amps that u have had success with these subs or any type like them
