i have a 1200w xplode amp and two audiobahn subs that are 300w rms a piece. When i bridge my amp, and turn up the jams, my amp just shuts off. anyone know what the problem is???
clipping, not enough power going to it from the alternator, make sure you power/ground are hooked up correctly, make sure the ground is VERY clean to the metal scrape any paint ect... those are you possible problems. another one is xplode is a shitty amp
JJJoey
thanks ill check it out. and the only reason i got xplode is cause i got it cheap from a friend. im broke so cheap is good.
wat ohms are your subs because u might be running them in 2ohms bridged and alot of amps wont take that
JJJoey
i thought they where 4 ohms. and i made sure all the connections werre good and the POS still doesnt work. could they be 2 ohms. and is a XM-2200 GTX 2-ohm stable???
