Silver Member Username: JaackdethBurnett, WI United States Post Number: 117 Registered: Sep-04 | To power these--PPI DCX 12" subs. They are Dual 4 ohm, and can handle 1000 watts RMS each... 2-300 dollar range if possible, if not suggestions!!! |
Silver Member Username: Alias747MN Post Number: 406 Registered: Apr-05 | Do you have 2 of them? Are you sure they are 1000 wrms? From what I know they are 1000 watts max. http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14075 BTW, getting an amp that does 2000 wrms is gonna run you alot more than 2-300 bucks. |
Silver Member Username: JaackdethBurnett, WI United States Post Number: 118 Registered: Sep-04 | 2 of them yes. I thought it said somewhere 1000rms, but anyway, I need an amp. Hifonics?? |
