Biff Biffson Unregistered guest | this is going to sound stupid, but where is the USB hook up on this camera? thanks |
Silver Member Username: GromitPost Number: 370 Registered: Mar-05 | Biff, USB ports and other connectors are normally found hidden under a soft plastic cover. Just have a look round the outside of your camcorder and I'm sure you'll find (if you haven't already). It might also only be visible when the LCD screen is open, but that is a bit unusual. If all else fails there's always the RTFM approach. Good luck! |
Biff Biffson Unregistered guest | i've looked, there are 2 soft plastic covers that i found, one says VIDEO and is not a usb hook up, and the other says DC IN and is also some other kind of hook up. and i've looked with the LCD screen open and still nothing. and what's RTFM? |
Biff Biffson Unregistered guest | ok i found it, it was actually a hard plastic cover on one of the corners. Thanks Gromit. |
Silver Member Username: GromitPost Number: 375 Registered: Mar-05 | You're welcome, Biff Too bad I guessed "soft plastic"! Cheers. PS: RTFM is a rather unkind term, which I used in gentle jest here. You can Google it if you haven't worked it out already..... |
Biff Biffson Unregistered guest | RTFM, i would have if i had it. this is not my camera, and the person i borrowed it from is on vacation, so that's not going to work. |
Silver Member Username: GromitPost Number: 377 Registered: Mar-05 | http://product.samsung.com/cgi-bin/nabc/support/b2c_downloadcenter_detail.jsp?eU ser=&mobile=N&oid=74351&cntType=UM&cntId=249037&lang=EN ;-) |
