Single or Dual voice coil
Username: Kyleleduc
Post Number: 21
I dont really understand the difference between these two. I was looking into getting two infinity 1030w, but when I was looking at them on this one site I saw that there was an infinity 1032w, all that I can see is the difference is the 1032's have a dual voice coil. I was wondering... 1. What is dual voice coil 2. If it is realy needed and 3. Is it worth spending the extra money to get the dual voice coil sub. Here are the websites for both of the subs. If you could check them out and let me know if the voice coil is the only difference between the two subs,and if it is could u answer the three questions that i had. Thanks.
infinity 1030w
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=13351
infinity 1032w
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=13352
Username: Thrushdtd
New York
Post Number: 183
it all has to do with what amp you want to use and at waht impedance you want. If you are getting two of these then get the dual voice coil so you can wire them to 2 ohms and save money on an amp.
Username: Kyleleduc
Post Number: 25
so the dual voice coil subs will be better?
Username: Taylor17
Kopperl, Texas
Post Number: 2343
What amp do you have, or going to get?
Thats the only thing the voice coils have too do with.
