Amp Power & Ground Screws
Username: Tylermoncrief
Post Number: 32
Okay...My brother lost the power and ground screws to my amp.You know how most amps have the Square Fastener, Well I need those 2...I had another amp..Screws didnt fit..The screws I need are for a Directed Xtreme 1800x amp....Any know where I can find them
I looked around at stores they dont sell them
But they do sell ring terminals...Could I substitue those..I dont know if it works for
ground tho
KMARTXR
as long as you can make a good solid connection anything will work, if you can make ring terminals work with a solid connection it will be fine
