New Head unit, problem w/ left speakers
dc
After I got a new head unit installed, the audio that comes out of the left 2 speakers is terrible and sounds like they are blown. But the only time they do that is when I am playing a cd from my cd changer; when I listen to the radio or use the cd player in the head unit they work fine. Does anyone know what the problem might be?
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 2653
the DIN cable from changer to head unit may be defective.
take it back to where it was installed.
dc
No, I had the CD changer before I got the new head unit; and with the last head unit, the changer played fine. Any other suggestions on what the problem might be?
dc
Its an alpine head unit(alpine CDM-9821) and alpine changer if that helps.
Username: Glasswolf
Post Number: 2668
the changer you have may not be compatible with the new head unit.
not all of them are interchangeable.
