I have 2 12' Punch p3 dual voice coil , 4ohms subs rated at 500 rms, can I power them with a hifonics BX1500 amp? IS a mono amp a good choice for two dual voice coil subwoofers? or is there any other amp out there for a good price that i should considered checking out? ANd can I wired them @ 1ohm to get the most power?
yea wire them at 1ohm, that amp is stable at 1ohm, and that amp only puts out 1000watts true power(friend had one and we had it tested), the amp isn't that great tho, i would consider a different amp especially since you have nice subs. it's not a bad amp for the price though
