Water Unregistered guest | What wires do you pros prefer 1200 watt rockford t amp 400 watt eclipse amp eclipse HU diamond coponets 5way rears all high quality stuff shops ripping me off with wires some one show me a place here i can get the best wires weather all in 1 store or 4-5 diffrent stores thank you all my 1st serious set up and i wanna do it correctly all i know is prices and nothing about wires |
Silver Member Username: IlluminatorPost Number: 475 Registered: Apr-05 | Knukonceptz has good wire, and Rockford Fosgate would be worth checking out. For main power wire, get 4 or 2 gauge... |
Water Unregistered guest | Can you tell me what I need how many wires I know nothing on what i need how many wires? |
Silver Member Username: IlluminatorPost Number: 490 Registered: Apr-05 | To make things easy, get an amplifier installation kit from ebay or even Walmart. Just make sure it has a power distribution block that splits 4 or 2 gauge wire into two 8 gauge wires for each amp. Also, grab some 12 gauge speaker wire for your subs or whatever is running from the Rockford Fosgate 1200max amp. You shouldn't need anything else unless you're running new wire to the component and rear speakers. |
Silver Member Username: GeekbikePost Number: 124 Registered: Dec-04 | The kits at Walmart are crap, the wire gauges are always larger than they say. Find a 0 or 2 gauge kit off Ebay (4 is a bit small is all the values stated are RMS). Unless you want to piece it together and save a bit of money, but spend a bunch more time, just buy a kit. |
Gold Member Username: Suleman36Post Number: 1487 Registered: Feb-05 | www.knukonceptz.com |
water Unregistered guest | all rms |
Silver Member Username: IlluminatorPost Number: 501 Registered: Apr-05 | Hey, Knacko, what brand of wiring do your local Walmarts carry? |
Silver Member Username: Riebread77Post Number: 109 Registered: Jun-05 | If money is no object go with stinger or streetwires...top of the line stuff |
