is there a big diffrenece if you moutnt he subs regular with the magnet inside the box or if you mount them inverted iwth the magnet sitcking on hte outside of the box?
i don't know TOO much into the mounting styles... i just know that it dosen't make a big of enough difference to mount it one way or the other.. it DOES make a difference if you get that much into detail, but you won't notice a difference
