Help!!!!!!
Username: Kicker
Slave lake, Alberta Canada
Post Number: 7
how do you hook up 4 cvr12" kicker dual voice coil sub to one 2 channel amp 850.2 kicker keeping it at 2ohms
you dont know me
no possible. you cant get a 2 ohm load with all four of them, your gonna get like 1/2 ohm or something like that
Username: Kicker
Post Number: 8
is that o.k or not
you dont know me
umm i think that amp will end up blowing pretty soon. you'll have to look at some wiring diagrams to get a load that isn't too low b/c running that low will make that amp run realllllllll hot and it'll burn it up
Username: Sq_junkie
Anchorage, AK US
Post Number: 42
Like this:
Wire each subs vc's to make them 2 ohms eg.:
2 2 2 2
Now wire two sets of subs in series with each other:
2-2 2-2
(4) (4)
Now wire these 4's in parallel and voila!
Username: Kicker
Post Number: 9
thanks that helped
