i was just wondering what kind of speakers i should get for my car...
it is an 88 olds....the only speakers in the front are 3.5" i believe....there are none in the doors...the rear has 6x9's i believe... i was looking at those infinity perfects for the rear...should i try "making room" for some in the front as well?
i am also planning on getting an RE xxx 12" sub for the rear....
also i was wondering if i would need to upgrade my head unit...ive had it for a few years...it is a pioneer DEH-P77DH
either way im looking to spend under 1500 (also if you have input on an amp to power that sub i would appreciate it)
